0003058 | ParaView | (No Category) | public | 2006-03-29 16:27 | 2007-04-09 13:02 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003058: Add current time value to the annotation | ||||||||
Description | This may be part of a larger 'annotation' item, but it is a common item, and it would be great to have it for our users as they test interim releases. | ||||||||
(0005369) Berk Geveci (administrator) 2006-10-12 10:46 |
This should be handle better than in paraview 2. |
(0005993) Utkarsh Ayachit (administrator) 2006-12-18 16:16 |
Groundwork for BUG#3058. Added a new source Text for which the system creates TextWidget as the display which is dragable. Added pqDisplayPolicy which is manager that dictates the applications policy for creating displays. API Change: pqPipelineBuilder::createSource no longer takes render module as an argument. The operation of creating a source and then creating its display cannot be condensed into an atomic task anymore (atleast not at the pipeline builder level) /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.34; previous revision: 1.33 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayManager.cxx,v <-- pqDisplayManager.cxx new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayManager.h,v <-- pqDisplayManager.h new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditorWidget.cxx,v <-- pqDisplayProxyEditorWidget.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditorWidget.h,v <-- pqDisplayProxyEditorWidget.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.67; previous revision: 1.66 /cvsroot/ParaView3/ParaView3/Qt/Components/pqTextDisplayPropertiesWidget.cxx,v <-- pqTextDisplayPropertiesWidget.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqTextDisplayPropertiesWidget.h,v <-- pqTextDisplayPropertiesWidget.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqXYPlotDisplayProxyEditor.h,v <-- pqXYPlotDisplayProxyEditor.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqTextDisplayPropertiesWidget.ui,v <-- pqTextDisplayPropertiesWidget.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.45; previous revision: 1.44 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.h,v <-- pqApplicationCore.h new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Core/pqConsumerDisplay.cxx,v <-- pqConsumerDisplay.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqConsumerDisplay.h,v <-- pqConsumerDisplay.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- pqDisplayPolicy.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.h,v <-- pqDisplayPolicy.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqGenericViewModule.cxx,v <-- pqGenericViewModule.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqGenericViewModule.h,v <-- pqGenericViewModule.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineBuilder.cxx,v <-- pqPipelineBuilder.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineBuilder.h,v <-- pqPipelineBuilder.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineModel.cxx,v <-- pqPipelineModel.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotViewModule.cxx,v <-- pqPlotViewModule.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotViewModule.h,v <-- pqPlotViewModule.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqReaderFactory.cxx,v <-- pqReaderFactory.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerManagerModel.cxx,v <-- pqServerManagerModel.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTableViewModule.cxx,v <-- pqTableViewModule.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTableViewModule.h,v <-- pqTableViewModule.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTextWidgetDisplay.cxx,v <-- pqTextWidgetDisplay.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTextWidgetDisplay.h,v <-- pqTextWidgetDisplay.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/Testing/BasicApp.cxx,v <-- BasicApp.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMNew3DWidgetProxy.cxx,v <-- vtkSMNew3DWidgetProxy.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.115; previous revision: 1.114 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/sources.xml,v <-- sources.xml new revision: 1.45; previous revision: 1.44 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.72; previous revision: 1.71 |
(0006010) Utkarsh Ayachit (administrator) 2006-12-19 14:21 |
For showing current time, we can link the "Text" property from the TextSource to a "group of properties", eg. global time keeper's time property etc. Additionally, there must be a mechanism to indicate how these property values are converted to a single string that gets displayed. |
(0006730) Berk Geveci (administrator) 2007-03-12 15:08 |
Create a sub-class of text actor that substitutes a special sequence with pipeline time. |
(0007051) Berk Geveci (administrator) 2007-04-02 12:47 |
Create a time text filter that produces the time as a string array (either in field data or as vtkTable). Create a special display that delivers this to the client and sets the value as a property of the text widget. |
(0007086) Utkarsh Ayachit (administrator) 2007-04-02 22:20 |
Adding vtkTimeToTextConvertor which converts the data set time to vtkTable whih is suitable for displaying using a text display. /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.132; previous revision: 1.131 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTimeToTextConvertor.cxx,v <-- vtkTimeToTextConvertor.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTimeToTextConvertor.h,v <-- vtkTimeToTextConvertor.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMConsumerDisplayProxy.cxx,v <-- vtkSMConsumerDisplayProxy.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMConsumerDisplayProxy.h,v <-- vtkSMConsumerDisplayProxy.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataObjectDisplayProxy.cxx,v <-- vtkSMDataObjectDisplayProxy.cxx new revision: 1.38; previous revision: 1.37 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTextDisplayProxy.cxx,v <-- vtkSMTextDisplayProxy.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTextDisplayProxy.h,v <-- vtkSMTextDisplayProxy.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.212; previous revision: 1.211 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.148; previous revision: 1.147 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewFilters.xml,v <-- ParaViewFilters.xml new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- pqDisplayPolicy.cxx new revision: 1.18; previous revision: 1.17 |
(0007119) Ken Moreland (manager) 2007-04-03 17:57 |
I'm confused. How, exactly, do you now show the current time in annotation? |
(0007126) Utkarsh Ayachit (administrator) 2007-04-03 23:25 |
Here's how to show a reader's/filter's time. * Create the reader/filer. * Add "Annotate Time" filter to it. The output from this filter is shown as text (same as TextSource). The text updates when the reader data time changes. Note that this filter only shows the data time from the source/filter at its input. |
(0007155) Utkarsh Ayachit (administrator) 2007-04-05 09:59 |
Create a source for time annotation showing by the update time. |
(0007159) Utkarsh Ayachit (administrator) 2007-04-05 12:11 |
Adding a time annotation text source which can show update time request. Simply create "Annotate Time" source and it shall do the rest! /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTimeToTextConvertor.cxx,v <-- vtkTimeToTextConvertor.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTimeToTextConvertor.h,v <-- vtkTimeToTextConvertor.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/sources.xml,v <-- sources.xml new revision: 1.57; previous revision: 1.56 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewFilters.xml,v <-- ParaViewFilters.xml new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewSources.xml,v <-- ParaViewSources.xml new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- pqDisplayPolicy.cxx new revision: 1.19; previous revision: 1.18 |
