0003064 | ParaView | (No Category) | public | 2006-03-30 16:58 | 2006-08-22 16:12 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003064: Create view toolbar | ||||||||
Description | The following buttons, which operate on the current window (and current dataset, when appropriate) should be implemented on a view toolbar: 1) reset center of rotation to the center of the current dataset 2) Reset the view to show everything visible 3) 'Back' in the current view stack 4) 'Forward' in the current view stack 5) (low priority) 'Save' current camera position (with name and thumbnail) 6) (low priority) Pulldown of saved camera positions. | ||||||||
(0004675) Berk Geveci (administrator) 2006-08-17 15:05 |
1 and 3 are done. Instead of 3 and 4, we will do the following: Quoting David Rogers: We need to have a 'forward' and 'back' button on the top bar of a QVTKWidget that lets the user go 'back' and 'forward' in the view stack. This functionality is already there - on the View menu - but we need it associated with a particular window. I think if it looked like a browser-type stuff … that would be cool |
(0004715) Utkarsh Ayachit (administrator) 2006-08-22 16:12 |
ENH: Fixes part of Bug 0003064 - Create view toolbar by adding back-forward buttons to the multiview. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMultiViewFrame.cxx,v <-- pqMultiViewFrame.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderWindowManager.cxx,v <-- pqRenderWindowManager.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqMultiViewFrameMenu.ui,v <-- pqMultiViewFrameMenu.ui new revision: 1.2; previous revision: 1.1 |
