0003127 | ParaView | (No Category) | public | 2006-04-13 17:26 | 2009-05-13 13:59 | ||||
Reporter | Brian Wylie | ||||||||
Summary | 0003127: Easy sideset normals | ||||||||
Description | Please add a button to show the sideset normals. Right now you have to construct the following pipeline in ParaView exodus(select just the sidesets) -> extract surface -> polydata normals -> glyph Too complicated, many users want to check boundary conditions, which include the orientation of their sidesets. So this should be a one button functionality. | ||||||||
(0004673) Berk Geveci (administrator) 2006-08-17 14:55 |
This sounds like a good candidate for a custom filter. |
(0011079) Berk Geveci (administrator) 2008-04-07 11:18 |
Create a custom filter that does extract surface -> polydata normals -> glyph and include it as an example in paraview source. Maybe write a test with it too? |
(0011648) Berk Geveci (administrator) 2008-05-01 13:29 |
Create a custom filter and compile it in. |
(0012423) Utkarsh Ayachit (administrator) 2008-06-19 15:17 |
Added new "Normal Glyphs" filter that adds a new custom filter for side set normals. Fixes BUG 0003127. I am not sure what properties need to be exposed (or what to call this filter). I am open to suggestions. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCompoundSourceProxy.cxx,v <-- Servers/ServerManager/vtkSMCompoundSourceProxy.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxy.cxx,v <-- Servers/ServerManager/vtkSMProxy.cxx new revision: 1.104; previous revision: 1.103 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxy.h,v <-- Servers/ServerManager/vtkSMProxy.h new revision: 1.88; previous revision: 1.87 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.cxx,v <-- Servers/ServerManager/vtkSMProxyManager.cxx new revision: 1.73; previous revision: 1.72 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.298; previous revision: 1.297 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewFilters.xml,v <-- Qt/Components/Resources/XML/ParaViewFilters.xml new revision: 1.48; previous revision: 1.47 |
(0012485) Alan Scott (manager) 2008-06-23 21:00 |
Nice. I wouldn't change a thing. Tested client/server. |
2008-04-07 11:18 | Berk Geveci | Note Added: 0011079 | |
2008-04-07 11:18 | Berk Geveci | Priority | low => normal |
2008-04-07 11:18 | Berk Geveci | Category | => 3.4 |
2008-04-07 11:18 | Berk Geveci | Description Updated | |
2008-05-01 13:29 | Berk Geveci | Note Added: 0011648 | |
2008-06-03 11:12 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-06-19 15:17 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-19 15:17 | Utkarsh Ayachit | Resolution | open => fixed |
2008-06-19 15:17 | Utkarsh Ayachit | Note Added: 0012423 | |
2008-06-23 21:00 | Alan Scott | Status | @80@ => closed |
2008-06-23 21:00 | Alan Scott | Note Added: 0012485 | |
