0003139 | ParaView | (No Category) | public | 2006-04-18 11:12 | 2009-12-09 14:57 | ||||
Reporter | stebo4u | ||||||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0003139: Contour Z-Buffer fails after application of transparency | ||||||||
Description | After setting the opacity of a contour to less then 1.0, the rendered image looks really wired: the back faces were draw in front if the Z-axis points 'into the monitor'. This was experienced only with a large raw 3D dataset, for a small dataset rendering was fine. | ||||||||
(0004001) stebo4u (reporter) 2006-04-18 11:26 |
Sorry, this also happens for small datasets. |
(0004002) stebo4u (reporter) 2006-04-18 11:44 |
Sorry, I didn't noticed the tooltip at first, which explaines that and why such artifacts will appear. |
(0018746) Berk Geveci (administrator) 2009-12-09 14:57 |
We now use depth peeling on cards that support it. |
2009-12-09 14:57 | Berk Geveci | Note Added: 0018746 | |
2009-12-09 14:57 | Berk Geveci | Status | tabled => closed |
2009-12-09 14:57 | Berk Geveci | Resolution | open => fixed |
