0003167 | ParaView | (No Category) | public | 2006-04-25 17:33 | 2006-11-22 16:53 | ||||
Reporter | David Rogers | ||||||||
Assigned To | Timothy Shead | ||||||||
Summary | 0003167: test recording that uses file browser does not work | ||||||||
Description | Playing back a simple file open test does not work. | ||||||||
Attached Files | test_save-restore.xml [^] (640 bytes) 1969-12-31 19:00 replay_init.jpg [^] (172,259 bytes) 1969-12-31 19:00 replay_result_paraq.jpg [^] (177,496 bytes) 1969-12-31 19:00 test_save-restore2.xml [^] (439 bytes) 1969-12-31 19:00 | ||||||||
(0004032) Timothy Shead (reporter) 2006-04-26 10:15 |
Fixed the immediate problems with playback, but still need to create a custom event translator/player to allow all user interaction with the file browser to be captured. |
(0004033) David Rogers (reporter) 2006-04-26 11:12 |
Test replays now, but gives incorrect results. See init and result images attached. |
(0004040) Timothy Shead (reporter) 2006-04-27 19:33 |
Added a custom event translator/player for the file dialog; this test case recording of "normal" interaction with the file dialog. |
