0003338 | ParaView | (No Category) | public | 2006-06-07 14:11 | 2007-04-03 17:01 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003338: Design new Scalar Bar/lookup table UI | ||||||||
Description | Need to replicate functionality of the current scalar bar/lookup table editor. See PQ wiki page http://www.paraview.org/ParaQ/index.php/Lookup_Table_Editing [^] | ||||||||
(0004840) Berk Geveci (administrator) 2006-09-04 11:32 |
We need to be able to set the end scalar values and also reset. Start thinking about how we will handle lookup tables. In ParaView 2, we assign one lookup table per array name and update it's range based on the range of all arrays. Should we allow users to create/load/save their own lookup tables? |
(0007048) Mark Richardson (reporter) 2007-04-02 12:37 |
I believe this one is finally done. I redesigned the dialog according to our last discussion. Volume rendering support is also complete. The same dialog is used to edit the color map for volume and surface rendering. The user can add and remove points. The can also save and reload preset color maps. |
(0007117) Ken Moreland (manager) 2007-04-03 17:01 |
The design of the editor looks good. I notice that the "Use Logarithmic Scale" checkbox does not seem to do anything. I assume that is still being worked on under bug 0004129. I also added the tangential bug 0004778. |
