0003415 | ParaView | (No Category) | public | 2006-06-16 11:23 | 2016-08-12 09:57 | ||||
Summary | 0003415: SNL: PVR: Axis and Widgets drawn on top in Ordered Composite mode | ||||||||
Description | When Ordered Compositing is on, the axis and any 3D widgets are drawn on top of most of the geometry. The problem is that the geometry is replicated on all the processes without being clipped. Thus, the geometry drawn on the "nearest" process is assumed to be on top of all other geometry. A good fix would be to pass the kd-tree to the display proxy responsible for the axis and 3D widgets and then clip the geometry by the appropriate region. | ||||||||
(0037497) Kitware Robot (administrator) 2016-08-12 09:57 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037497 | |
