0003434 | ParaView | (No Category) | public | 2006-06-22 18:04 | 2006-08-22 15:24 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003434: Variable selector: remove '(cell)' and '(point)' text from combo box | ||||||||
Description | We don't need the text indicating 'cell' or 'point' variables, as this is taken care of by the icon in the combo box. Additionally, this clutters up the name of the variable. | ||||||||
(0004714) Utkarsh Ayachit (administrator) 2006-08-22 15:24 |
ENH: Fixes Bug 0003434 (Variable selector: remove '(cell)' and '(point)' text from combo box). Also changed the DisplayProxyEditor to use the DisplayColorWidget and DisplayRepresentationWidget instances instead of create its own logic for managing the same. Needed to fix the tests to refer to the changes widget names. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.cxx,v <-- pqDisplayColorWidget.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.h,v <-- pqDisplayColorWidget.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- pqDisplayProxyEditor.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.h,v <-- pqDisplayProxyEditor.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayRepresentationWidget.cxx,v <-- pqDisplayRepresentationWidget.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayRepresentationWidget.h,v <-- pqDisplayRepresentationWidget.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- pqDisplayProxyEditor.ui new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/ContourRange.xml,v <-- ContourRange.xml new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/Cut.xml,v <-- Cut.xml new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/ExodusPanel.xml,v <-- ExodusPanel.xml new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/StreamTracer.xml,v <-- StreamTracer.xml new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/StreamTracerUpdates.xml,v <-- StreamTracerUpdates.xml new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/Threshold.xml,v <-- Threshold.xml new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/VariableSelector.xml,v <-- VariableSelector.xml new revision: 1.6; previous revision: 1.5 |
