0003451 | ParaView | (No Category) | public | 2006-06-27 16:51 | 2006-09-26 09:15 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003451: Show variable information for each filter | ||||||||
Description | Create a widget like the variable widget in the Exodus reader for use in all filter inspector panels. It should have all the columns of the Exodus Reader Variable panel, except for the 'on/off' checkbox. | ||||||||
(0004832) Berk Geveci (administrator) 2006-09-02 13:25 |
There are a few issues with the current implementation: 1. It is not always possible to read the range. When the array name is too long, part of the array name and range is replaced with ... Since this is the only way to get the range of arrays, this is not acceptable 2. On OS X, the range (and the name of the array) is cut off completely. I am guessing we need a more custom widget for the menu. |
(0005036) Berk Geveci (administrator) 2006-09-26 09:15 |
The variable information will move to an information panel. |
