0003454 | ParaView | (No Category) | public | 2006-06-28 20:22 | 2009-12-09 14:51 | ||||
Reporter | Wendy Doyle | ||||||||
Summary | 0003454: Problems rendering Exodus Dataset w/ Beams | ||||||||
Description | This problem showed up in cvs sometime between 6/22 and 6/26. I've attached the problem dataset. There are repeated error messages after the "Accept" button is pushed in the Exodus reader and any time rendering is done. The error message says # Error or warning: There was a VTK Error in file: /home/wkoegle/util/src/ParaView-cvs/VTK/Rendering/vtkOpenGLPainterDeviceAdapter.cxx (439) ftkOpenGLPainterDeviceAdapater: Unsupported attribute index: 5 The parts in this dataset are beams = lines. If the display "color by" is changed from BlockID to property, the errors stop. Exodus datasets with hex parts do not have this problem. | ||||||||
Attached Files | displ-tear-exposeds.ex2 [^] (9,084 bytes) 1969-12-31 19:00 | ||||||||
(0004868) Utkarsh Ayachit (administrator) 2006-09-06 10:58 |
Fixed BUG# 3454. vtkStandardPolyDataPainter was sending attributes not supported by the device adaptor over for rendering. Fixed by adding API to device adaptor to query if an attribute is supported and sending only those that are supported by the device. /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkOpenGLPainterDeviceAdapter.cxx,v <-- vtkOpenGLPainterDeviceAdapter.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkOpenGLPainterDeviceAdapter.h,v <-- vtkOpenGLPainterDeviceAdapter.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkPainterDeviceAdapter.h,v <-- vtkPainterDeviceAdapter.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkStandardPolyDataPainter.cxx,v <-- vtkStandardPolyDataPainter.cxx new revision: 1.5; previous revision: 1.4 |
