0003464 | ParaView | (No Category) | public | 2006-06-30 12:50 | 2007-03-19 10:51 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003464: Change color ramp | ||||||||
Description | Current color ramp goes from red (low) to blue (hi). This must be reversed - blue (lo) to red (hi) | ||||||||
(0004841) Berk Geveci (administrator) 2006-09-04 11:34 |
Also add several default lookup tables. See bug 0003338 too. |
(0005328) Utkarsh Ayachit (administrator) 2006-10-10 10:59 |
Color map already goes from blue(low) to red(high) by default. Need to make color by magnitude default, as against color by 0th component. |
(0006698) Mark Richardson (reporter) 2007-03-09 12:32 |
Magnitude is now the default vector mode. |
(0006714) Ken Moreland (manager) 2007-03-12 10:23 |
ParaView 2 has a "CIELab" preset color map that is sometimes useful. It should be pretty easy to add to ParaView 3. Should the request go here, or in 0003338? |
