0003468 | ParaView | (No Category) | public | 2006-06-30 17:52 | 2009-12-09 14:50 | ||||
Reporter | Peter Bismuti | ||||||||
Summary | 0003468: ensight reader broken | ||||||||
Description | Unable to read ensightb.case generated by CFD++. Error message: ErrorMessage # Error or warning: There was a VTK Error in file: /acct/pjb9508/VTK/paraview-2.4.3/VTK/IO/vtkEnSight6BinaryReader.cxx (222) vtkEnSight6BinaryReader (0x1e7e760): Invalid number of unstructured points; check that ByteOrder is set correctly. ErrorMessage end ErrorMessage # Error or warning: There was a VTK Error in file: /acct/pjb9508/VTK/paraview-2.4.3/VTK/IO/vtkEnSightReader.cxx (270) vtkEnSight6BinaryReader (0x1e7e760): error reading geometry file ErrorMessage end ErrorMessage # Error or warning: There was a VTK Error in file: /acct/pjb9508/VTK/paraview-2.4.3/VTK/Filtering/vtkExecutive.cxx (688) vtkCompositeDataPipeline (0x1e817e0): Algorithm vtkEnSight6BinaryReader(0x1e7e760) returned failure for request: vtkInformation (0x1e9d5f0) Debug: Off Modified Time: 101795 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 KEYS_TO_COPY: UPDATE_BLOCKS FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 ErrorMessage end [2]+ Segmentation fault (core dumped) bin/paraview | ||||||||
(0007788) Berk Geveci (administrator) 2007-06-02 10:48 |
Not enough information to trace this. Is there an example dataset? |
2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView |
