0003479 | ParaView | (No Category) | public | 2006-07-03 23:46 | 2009-05-13 13:59 | ||||
Summary | 0003479: SNL: We need to be able to color blocks differently | ||||||||
Description | We need to be able to color blocks differently - using a different color map per block. For instance, if a user wants to select block number 30, and turn it red while leaving the rest of an object colored by tempurature. Or, a user may want ALL blocks blue, except for wanting block number 3000 to be red. | ||||||||
(0011084) Berk Geveci (administrator) 2008-04-07 11:37 |
This will be addressed by the easy block extraction filter. |
(0011395) Utkarsh Ayachit (administrator) 2008-04-16 11:07 |
You can use the "Extract Block" filter if you know which blocks you are interested in. Alternatively, you can "pick" blocks on the screen (by pressing "B" and then clicking on the 3D view) and then create a "Extract Selection" filter. |
(0011426) Alan Scott (manager) 2008-04-17 20:48 |
Fabulous!! Tested client/server |
2008-04-07 11:36 | Berk Geveci | Assigned To | System Admin => Utkarsh Ayachit |
2008-04-07 11:36 | Berk Geveci | Priority | low => normal |
2008-04-07 11:36 | Berk Geveci | Category | => 3.4 |
2008-04-07 11:37 | Berk Geveci | Note Added: 0011084 | |
2008-04-16 11:07 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-16 11:07 | Utkarsh Ayachit | Resolution | open => no change required |
2008-04-16 11:07 | Utkarsh Ayachit | Note Added: 0011395 | |
2008-04-17 20:48 | Alan Scott | Status | @80@ => closed |
2008-04-17 20:48 | Alan Scott | Note Added: 0011426 | |
