0003528 | ParaView | (No Category) | public | 2006-07-20 06:48 | 2016-08-12 09:57 | ||||
Reporter | Daniel Tourde | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0003528: Problems with hdf5_zlib.h: vtk_zlib.h is pointed instead of zlib.h | ||||||||
Description | Hello, I am trying to compile "by hand" Paraview 2.4.4 and I encounter a strange problem. To compile paraview, I follow the installation procedure and under CMAKE (2.4.2) I choose: BUILD_SHARED_LIBS : ON VTK_USE_SYSTEM_FREETYPE : ON VTK_USE_SYSTEM_JPEG : ON VTK_USE_SYSTEM_PNG : ON VTK_USE_SYSTEM_TIFF : ON VTK_USE_SYSTEM_ZLIB : ON When I build Paraview I then get the following error: In file included from /root/paraview-2.4.4/Utilities/hdf5/H5Zdeflate.c:30: /root/paraview-2.4.4-linux/Utilities/hdf5/hdf5_zlib.h:1:22: vtk_zlib.h: No such file or directory morghaan paraview-2.4.4-linux # cd /root/paraview-2.4.4-linux/Utilities/hdf5/ morghaan hdf5 # more hdf5_zlib.h #include <vtk_zlib.h> I have two Gentoo machines at my disposal: - One with VTK installed: I get this error message (the file is under /usr/include/vtk-5.0 and is apparently never found) - One without VTK, the file does not even exist... If I check the source code, I can see that this hdf5_zlib.h is, as a matter of fact, generated automatically: morghaan hdf5 # more hdf5_zlib.h.in #include <@HDF5_ZLIB_HEADER@> where morghaan hdf5 # more CMakeLists.txt gives: IF(NOT HDF5_ZLIB_HEADER) SET(HDF5_ZLIB_HEADER "zlib.h") ENDIF(NOT HDF5_ZLIB_HEADER) CONFIGURE_FILE(${VTKHDF5_SOURCE_DIR}/hdf5_zlib.h.in ${VTKHDF5_BINARY_DIR}/hdf5_zlib.h) So, I don't really understand why vtk_zlib.h is chosen instead of zlib.h when I clearly specify the flag... | ||||||||
(0037501) Kitware Robot (administrator) 2016-08-12 09:57 |
2010-11-17 09:22 | David Partyka | Assigned To | Berk Geveci => David Partyka |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037501 | |
