0003576 | ParaView | (No Category) | public | 2006-08-02 22:20 | 2010-01-18 22:14 | ||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0003576: SNL: Calculator error reporting is broken | ||||||||
Description | When running the calculator, if the formula isn't perfect, the display just goes blank. Open can.exo. Turn all node variables on. Hit accept. Click Calculator. Vectors, "DISPL", Accept. All is well. Type "+1" after the DISPL, hit Accept. Everything just goes blank. It is also reported that if you hand type in the data into the formula window, it doesn't work. I suspect that this is just an error in typed input, and the user can't tell. Example: type in DISPL, hit accept. It works. Type in DISLP, it doesn't. Type in =DISPL, it also doesn't work. Get rid of the =, it now works. There is a red ! at the bottom, if you look carefully. Message is pretty generic. | ||||||||
(0005265) Berk Geveci (administrator) 2006-10-05 14:58 |
We will handle error reporting much better in ParaView 3. I am postponing this until then. |
(0019183) Alan Scott (manager) 2010-01-18 22:14 |
Looks fixed to me. Tested both cases below, both reported correctly what the error was. Local server, XP, 3.6.2 |
2010-01-18 22:14 | Alan Scott | Note Added: 0019183 | |
2010-01-18 22:14 | Alan Scott | Status | tabled => closed |
2010-01-18 22:14 | Alan Scott | Resolution | open => fixed |
