0003603 | ParaView | Bug | public | 2006-08-11 10:54 | 2010-04-20 17:15 | ||||
Reporter | Randall Hand | ||||||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0003603: USE_TRANSMIT mode doesn't work | ||||||||
Description | When the data only exists on the Head Node (process 0) of a parallel server and PV_USE_TRANSMIT is enabled, then the data should only be loaded on the single 0 process and then MPI transmit to the other nodes ( as specified in http://paraview.org/Wiki/ParaView:FAQ#Why_does_it_take_so_long_to_read_my_files_in_parallel_.3F [^] ) Unfortunately, right now every process attempts (and fails) to load it individually. According to Berk Geveci this feature is not being testing, and has become accidentally broken. | ||||||||
(0019023) Utkarsh Ayachit (administrator) 2010-01-04 13:53 |
Berk, Looking at vtkSMOutputPort.cxx, looks like this FAQ needs to be updated to refer to environment variable PV_LOCK_SAFE. Seems like the variable was changed ages ago. |
(0020210) Utkarsh Ayachit (administrator) 2010-04-16 01:58 |
As mentioned, the name for the environment variable was changed in ParaView 2.* itself. |
(0020300) Alan Scott (manager) 2010-04-20 17:15 |
Trusting Utkarsh. If this is still broken, please reopen. |
2009-12-09 17:24 | Berk Geveci | Priority | normal => high |
2009-12-09 17:24 | Berk Geveci | Category | => Bug |
2009-12-09 17:24 | Berk Geveci | Target Version | => 3.8 |
2010-01-04 13:53 | Utkarsh Ayachit | Note Added: 0019023 | |
2010-04-16 01:58 | Utkarsh Ayachit | Note Added: 0020210 | |
2010-04-16 01:58 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-04-16 01:58 | Utkarsh Ayachit | Resolution | open => no change required |
2010-04-20 17:15 | Alan Scott | Note Added: 0020300 | |
2010-04-20 17:15 | Alan Scott | Status | @80@ => closed |
