0003620 | ParaView | (No Category) | public | 2006-08-16 12:48 | 2009-05-13 13:59 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0003620: compound proxies w/ UpdatePipelineInformation() | ||||||||
Description | Create a compound proxy with an exodus reader and use it. The panel doesn't get generated correctly unless pqObjectPanel goes to the insides of the compound proxy and calls UpdatePipelineInformation(). See pqObjectPanel::setProxyInternal. | ||||||||
(0004655) Clinton Stimpson (developer) 2006-08-16 12:48 |
Berk can have it or assign it. |
(0004656) Clinton Stimpson (developer) 2006-08-16 12:56 |
For the exodus custom filter, expose the FileName, CellArrayStatus, and CellArrayInfo. |
(0011085) Berk Geveci (administrator) 2008-04-07 11:39 |
Can you check if this is still the case? |
(0011090) Clinton Stimpson (developer) 2008-04-07 11:50 |
It appears to work fine now. |
(0011355) Utkarsh Ayachit (administrator) 2008-04-15 16:41 |
Resolving since Clint acknowledged that this works fine now. |
(0011370) Alan Scott (manager) 2008-04-15 17:47 |
Closing since Clint acknowledged that it works fine now. |
2008-04-07 11:39 | Berk Geveci | Note Added: 0011085 | |
2008-04-07 11:39 | Berk Geveci | Priority | low => normal |
2008-04-07 11:39 | Berk Geveci | Category | => 3.4 |
2008-04-07 11:50 | Clinton Stimpson | Note Added: 0011090 | |
2008-04-15 16:41 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-15 16:41 | Utkarsh Ayachit | Resolution | open => no change required |
2008-04-15 16:41 | Utkarsh Ayachit | Note Added: 0011355 | |
2008-04-15 17:47 | Alan Scott | Status | @80@ => closed |
2008-04-15 17:47 | Alan Scott | Note Added: 0011370 | |
