0003626 | ParaView | (No Category) | public | 2006-08-17 14:52 | 2007-02-05 14:58 | ||||
Reporter | Mark Richardson | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0003626: Server connect doesn't highlight new server in pipeline browser. | ||||||||
Description | If you start paraview and connect to a builtin server, the new server item in the pipeline browser doesn't get highlighted. I fixed the problem a few weeks ago. It had something to do with the order of operations in the main window. The problem has resurfaced since the last server connect change. | ||||||||
(0004672) Mark Richardson (reporter) 2006-08-17 14:54 |
Tim, can you take a look at this. I believe you were the last to change the code. |
(0006269) Mark Richardson (reporter) 2007-01-25 17:19 |
While reworking the active server/source in the main window, I fixed this bug as well. |
