0003633 | ParaView | (No Category) | public | 2006-08-17 15:56 | 2006-08-21 15:22 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0003633: Add representation selection to the toolbar | ||||||||
Description | The representation (wireframe, solid etc.) of the current source/display should be selectable from the toolbar. | ||||||||
(0004705) Utkarsh Ayachit (administrator) 2006-08-21 15:22 |
Committed patch to add the selector. Also added a test. /cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.50; previous revision: 1.49 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.35; previous revision: 1.34 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- MainWindow.ui new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/RepresentationSelector.xml,v <-- RepresentationSelector.xml initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayRepresentationWidget.cxx,v <-- pqDisplayRepresentationWidget.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayRepresentationWidget.h,v <-- pqDisplayRepresentationWidget.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayRepresentationWidget.ui,v <-- pqDisplayRepresentationWidget.ui initial revision: 1.1 |
