0003669 | ParaView | (No Category) | public | 2006-08-28 15:49 | 2009-12-09 14:51 | ||||
Reporter | Brian Wylie | ||||||||
Summary | 0003669: SNL: ParaView 'Sequence' Animation broken on the cvs trunk | ||||||||
Description | The ParaView animation is broken on the cvs trunk. If you are in 'sequence' mode every frame is 1 second long. In the 2.4 branch if you are in 'sequence' mode the player seems to play the frames as quick as it can. In the cvs trunk each frame plays for 1 second. | ||||||||
(0005082) Utkarsh Ayachit (administrator) 2006-10-02 14:59 |
for PV2.*, we use the default frame rate specified by the file format instead of the one used to generate the frames." GUI/Client Servers/ServerManager /cvsroot/ParaView/ParaView/GUI/Client/vtkPVAnimationScene.cxx,v <-- vtkPVAnimationScene.cxx new revision: 1.69; previous revision: 1.68 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMAnimationSceneProxy.cxx,v <-- vtkSMAnimationSceneProxy.cxx new revision: 1.29; previous revision: 1.28 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMAnimationSceneProxy.h,v <-- vtkSMAnimationSceneProxy.hnew revision: 1.12; previous revision: 1.11 |
