0003692 | ParaView | (No Category) | public | 2006-09-01 12:59 | 2006-09-05 15:37 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0003692: clean command sometimes not issued for property | ||||||||
Description | create a pipeline cone source -> elevation -> point data to cell data -> poly data normals -> calculator put in '1' for the function and hit accept. then switch to cell data mode and put in '1' and hit accept. An error comes up about ERROR: In vtkArrayCalculator.cxx, line 284 vtkArrayCalculator (0x127e240): Invalid array name: Normals Normals is a point data, not a cell data as we are in cell data mode. What happened was the clean command for the AddVectorVariable property wasn't issued, so it didn't clean out the "Normals". | ||||||||
(0004851) Utkarsh Ayachit (administrator) 2006-09-05 15:37 |
The clean command was skipped when numElems was 0. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStringVectorProperty.cxx,v <-- vtkSMStringVectorProperty.cxx new revision: 1.27; previous revision: 1.26 |
