0003699 | ParaView | (No Category) | public | 2006-09-02 13:09 | 2006-09-26 09:19 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0003699: State loading bugs | ||||||||
Description | Load the attached state and then disconnect and load the state again. You will get errors like: ERROR: In /Users/berk/work/ParaView3/Servers/Common/vtkProcessModuleConnectionManager.cxx, line 165 vtkProcessModuleConnectionManager (0x27b48150): Invalid connection ID: 5 ERROR: In /Users/berk/work/ParaView3/Servers/Common/vtkProcessModuleConnectionManager.cxx, line 165 vtkProcessModuleConnectionManager (0x27b48150): Invalid connection ID: 5 ERROR: In /Users/berk/work/ParaView3/Servers/Common/vtkProcessModuleConnectionManager.cxx, line 165 vtkProcessModuleConnectionManager (0x27b48150): Invalid connection ID: 5 ERROR: In /Users/berk/work/ParaView3/Servers/Common/vtkProcessModuleConnectionManager.cxx, line 165 vtkProcessModuleConnectionManager (0x27b48150): Invalid connection ID: 6 Also, one Windows, loading the state produces the following errors: QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPixmap::fromWinHBITMAP(), failed to get bitmap bits QPainter::begin(), paintdevice returned engine == 0, type: 2 | ||||||||
Attached Files | test3.pvsm [^] (45,483 bytes) 1969-12-31 19:00 | ||||||||
(0004850) Utkarsh Ayachit (administrator) 2006-09-05 14:50 |
cvs ci -m"BUG: Fixes part of BUG#3699. Selection proxies would hang around after server disconnect. Cleaned that up. " Qt Checking for path: /cvsroot/ParaView3/ParaView3/Qt/Components Unrestricted user: utkarsh Checking for path: /cvsroot/ParaView3/ParaView3/Qt/Core Unrestricted user: utkarsh /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.cxx,v <-- pqSelectionManager.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.h,v <-- pqSelectionManager.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.20; previous revision: 1.19 |
