0003708 | ParaView | (No Category) | public | 2006-09-04 11:29 | 2006-09-05 11:12 | ||||
Reporter | Berk Geveci | ||||||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0003708: Crash when creating a cut/clip custom filter | ||||||||
Description | Try this: * Create a sphere * Create a clip filter * Create custom filter with only clip. Assign input and outputs. * Apply the custon filter to the sphere * CRASH Are we handling 3d widgets in custom filters? | ||||||||
(0004847) Utkarsh Ayachit (administrator) 2006-09-05 11:12 |
The problem was that pv would try to create a custom panel for the custom filter if the custom filter was named same as any of the supported custom panels (eg.Clip/Cut) which would lead to crash since such panels assume the type of proxy. Fixed that be adding API to the panel interface to use the proxy itself to tell if the panel suppports the proxy rather than just the name. /cvsroot/ParaView3/ParaView3/Qt/Components/pqCalculatorPanel.cxx,v <-- pqCalculatorPanel.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCalculatorPanel.h,v <-- pqCalculatorPanel.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqClipPanel.cxx,v <-- pqClipPanel.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqClipPanel.h,v <-- pqClipPanel.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqContourPanel.cxx,v <-- pqContourPanel.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqContourPanel.h,v <-- pqContourPanel.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCutPanel.cxx,v <-- pqCutPanel.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCutPanel.h,v <-- pqCutPanel.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.cxx,v <-- pqExodusPanel.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.h,v <-- pqExodusPanel.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectInspectorWidget.cxx,v <-- pqObjectInspectorWidget.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectPanelInterface.h,v <-- pqObjectPanelInterface.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectPanelLoader.cxx,v <-- pqObjectPanelLoader.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectPanelLoader.h,v <-- pqObjectPanelLoader.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqStreamTracerPanel.cxx,v <-- pqStreamTracerPanel.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqStreamTracerPanel.h,v <-- pqStreamTracerPanel.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqThresholdPanel.cxx,v <-- pqThresholdPanel.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqThresholdPanel.h,v <-- pqThresholdPanel.h new revision: 1.4; previous revision: 1.3 |
