0003722 | ParaView | Bug | public | 2006-09-06 14:49 | 2011-01-13 17:00 | ||||
Priority | immediate | Severity | feature | Reproducibility | always | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0003722: SNL: Select by value | ||||||||
Description | We have had many requests for the ability to select elements or nodes based on a variable value. The simple version of this is "I want to see the element or node with the max temperature at this time step." From RT bug 1171. | ||||||||
(0005424) Berk Geveci (administrator) 2006-10-16 13:48 |
Can we delay this until pv 3? |
(0019595) Utkarsh Ayachit (administrator) 2010-02-23 13:00 |
Added new "Edit | Find Data" dialog which allows the user to create a selection using a query dialog. /cvsroot/ParaView3/ParaView3/Applications/ParaView/Testing/XML/CMakeLists.txt,v <-- Applications/ParaView/Testing/XML/CMakeLists.txt new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Applications/ParaView/Testing/XML/FindDataDialog.xml,v <-- Applications/ParaView/Testing/XML/FindDataDialog.xml initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/CMakeLists.txt,v <-- Qt/ApplicationComponents/CMakeLists.txt new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqDataQueryReaction.cxx,v <-- Qt/ApplicationComponents/pqDataQueryReaction.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqDataQueryReaction.h,v <-- Qt/ApplicationComponents/pqDataQueryReaction.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqParaViewMenuBuilders.cxx,v <-- Qt/ApplicationComponents/pqParaViewMenuBuilders.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/Resources/UI/pqEditMenuBuilder.ui,v <-- Qt/ApplicationComponents/Resources/UI/pqEditMenuBuilder.ui new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.180; previous revision: 1.179 /cvsroot/ParaView3/ParaView3/Qt/Components/pqQueryClauseWidget.cxx,v <-- Qt/Components/pqQueryClauseWidget.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqQueryClauseWidget.h,v <-- Qt/Components/pqQueryClauseWidget.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqQueryDialog.cxx,v <-- Qt/Components/pqQueryDialog.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqQueryDialog.h,v <-- Qt/Components/pqQueryDialog.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.cxx,v <-- Qt/Components/pqSelectionInputWidget.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- Qt/Components/pqSelectionInspectorPanel.cxx new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.cxx,v <-- Qt/Components/pqSelectionManager.cxx new revision: 1.71; previous revision: 1.70 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.h,v <-- Qt/Components/pqSelectionManager.h new revision: 1.41; previous revision: 1.40 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.h,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqQueryClauseWidget.ui,v <-- Qt/Components/Resources/UI/pqQueryClauseWidget.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqQueryCompositeTreeDialog.ui,v <-- Qt/Components/Resources/UI/pqQueryCompositeTreeDialog.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqQueryDialog.ui,v <-- Qt/Components/Resources/UI/pqQueryDialog.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui,v <-- Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- Qt/Core/CMakeLists.txt new revision: 1.117; previous revision: 1.116 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOutputPort.h,v <-- Qt/Core/pqOutputPort.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetView.cxx,v <-- Qt/Core/pqSpreadSheetView.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetView.h,v <-- Qt/Core/pqSpreadSheetView.h new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.cxx,v <-- Qt/Core/pqSpreadSheetViewModel.cxx new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.h,v <-- Qt/Core/pqSpreadSheetViewModel.h new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewWidget.cxx,v <-- Qt/Core/pqSpreadSheetViewWidget.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewWidget.h,v <-- Qt/Core/pqSpreadSheetViewWidget.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.211; previous revision: 1.210 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkQuerySelectionSource.cxx,v <-- Servers/Filters/vtkQuerySelectionSource.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkQuerySelectionSource.h,v <-- Servers/Filters/vtkQuerySelectionSource.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/sources.xml,v <-- Servers/ServerManager/Resources/sources.xml new revision: 1.102; previous revision: 1.101 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkSelectionNode.cxx,v <-- VTK/Filtering/vtkSelectionNode.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkSelectionNode.h,v <-- VTK/Filtering/vtkSelectionNode.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedBlock.cxx,v <-- VTK/Graphics/vtkExtractSelectedBlock.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedThresholds.cxx,v <-- VTK/Graphics/vtkExtractSelectedThresholds.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedThresholds.h,v <-- VTK/Graphics/vtkExtractSelectedThresholds.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.cxx,v <-- VTK/Graphics/vtkSelectionSource.cxx new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.h,v <-- VTK/Graphics/vtkSelectionSource.h new revision: 1.14; previous revision: 1.13 |
(0019784) Alan Scott (manager) 2010-03-09 21:35 |
Oh my, that is amazing. Great, great great. Tested XP, local server, trunk. I think there may be a few ease of use issues, but lets get it out and see what users think. |
2010-02-01 14:30 | Utkarsh Ayachit | Priority | low => immediate |
2010-02-01 14:30 | Utkarsh Ayachit | Category | => Bug |
2010-02-01 14:30 | Utkarsh Ayachit | Assigned To | Berk Geveci => |
2010-02-23 12:56 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-02-23 12:56 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-02-23 13:00 | Utkarsh Ayachit | Note Added: 0019595 | |
2010-02-23 13:00 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-02-23 13:00 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-02-23 13:00 | Utkarsh Ayachit | Resolution | open => fixed |
2010-03-09 21:35 | Alan Scott | Note Added: 0019784 | |
2010-03-09 21:35 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
