0003724 | ParaView | (No Category) | public | 2006-09-06 19:24 | 2008-04-07 17:36 | ||||
Assigned To | Alan Scott | ||||||||
Priority | low | Severity | minor | Reproducibility | unable to reproduce | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0003724: SNL: Composite/Geometry bug | ||||||||
Description | There appears to be the following strange bug. 1. Set Composite slider to 10 MB 2. Set Bounding Box Threshold slider to something small 3. Open data 4. Adjust bounding box size to 500M cells (the data set stays as a bounding box) 5. Change display type on the reader to surface At this point, ParaView appears to be sending all of the geometry down to the client even though the data is larger than 10 MB. The client hung for about 10 minutes during this period. The solution was prior to opening data, make sure the composite slider is at 0MB and the Bounding Box Threshold slider was at 500M cells. | ||||||||
(0005611) Amy Squillacote (reporter) 2006-10-30 16:20 |
Hi Alan, Berk and I tried to reproduce this bug both in ParaView 2.4 and on the CVS HEAD, but we were unable to reproduce this bug. Will you please verify that this problem still exists, and if it does please send us more information about how to reproduce the problem. Thanks, Amy |
(0011086) Berk Geveci (administrator) 2008-04-07 11:42 |
Alan, Can you check if this bug exists in ParaView 3? |
(0011127) Alan Scott (manager) 2008-04-07 17:36 |
This appears resolved. Tested client/server, trunk as of April 7, 2008. |
2007-08-03 17:35 | Berk Geveci | Project | @5@ => ParaView |
2007-08-03 17:37 | Berk Geveci | Note Deleted: 0008147 | |
2007-08-03 17:38 | Berk Geveci | Assigned To | Bob O'Bara => Berk Geveci |
2007-08-03 17:38 | Berk Geveci | Priority | high => low |
2007-08-03 17:38 | Berk Geveci | Reproducibility | always => unable to reproduce |
2007-08-03 17:38 | Berk Geveci | Resolution | duplicate => unable to reproduce |
2007-08-03 17:57 | Berk Geveci | Summary | Goodsite => SNL: Composite/Geometry bug |
2008-04-07 11:42 | Berk Geveci | Note Added: 0011086 | |
2008-04-07 11:42 | Berk Geveci | Assigned To | Berk Geveci => Alan Scott |
2008-04-07 17:36 | Alan Scott | Status | tabled => closed |
2008-04-07 17:36 | Alan Scott | Note Added: 0011127 | |
