0003758 | ParaView | (No Category) | public | 2006-09-11 19:15 | 2008-04-07 11:45 | ||||
Reporter | Brian Wylie | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0003758: Redundant icons | ||||||||
Description | The statistics view has multiple redudant icons. The "Data", "No of Cells" and "No of Points" all have icons and text telling you the same thing. In my opinion the icons are redudant and simply cause visual clutter without adding information. Also the 'Data Bounds' column should be renamed 'Spatial Bounds' to better reflect what information it's providing. | ||||||||
(0007485) Ken Moreland (manager) 2007-04-26 12:10 |
I changed the "Data Bounds" to "Spatial Bounds". I also changed the "Data" header to "Data Type". I have not changed anything else, because I am not in total agreement that the icons are worthless. The Data Type icon does give an indication of the data type that is faster to recognize that reading the text. The icons under No. of Cells/Points help identify the data without having to reference back up to the header of the column. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDataInformationModel.cxx,v <-- pqDataInformationModel.cxx new revision: 1.7; previous revision: 1.6 |
(0011088) Berk Geveci (administrator) 2008-04-07 11:45 |
Talk to Ken :-) |
2008-04-07 11:45 | Berk Geveci | Status | tabled => closed |
2008-04-07 11:45 | Berk Geveci | Note Added: 0011088 | |
2008-04-07 11:45 | Berk Geveci | Resolution | open => won't fix |
