0003761 | ParaView | (No Category) | public | 2006-09-11 19:35 | 2007-09-13 16:58 | ||||
Reporter | Brian Wylie | ||||||||
Summary | 0003761: Element inspector | ||||||||
Description | If I select in element in the element inspector (lets say I have 10 elements listed) I would like that selection to 'highlight' in the VTK window. Also I would like to be able to shift/ctrl select. | ||||||||
(0007482) Ken Moreland (manager) 2007-04-26 11:49 |
This sounds like a good compliment to the labeling required for the annotation deliverable of PV 3.2. |
(0008809) Berk Geveci (administrator) 2007-09-03 10:54 |
This works well. There are a few minor glitches in the selection that Utkarsh will look at. |
(0008817) Utkarsh Ayachit (administrator) 2007-09-04 10:42 |
There seems to be as issue on Mac (this works fine on Windows and Linux). If one shift-selects beyond a block boundary, the tree widget doesn't show the rows as selected correctly. However, this issue is only with the table view not showing selection properly, all cells indeed get selected (can be verified on the selection inspector) and the 3D view even shows the selection correctly. |
(0008900) Utkarsh Ayachit (administrator) 2007-09-10 09:21 |
Adding a new lower priority bug to address the Mac issue with showing the selection correctly (BUG 0005669). |
2007-08-13 15:09 | Berk Geveci | Priority | normal => high |
2007-09-03 10:54 | Berk Geveci | Note Added: 0008809 | |
2007-09-03 10:54 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-09-04 10:42 | Utkarsh Ayachit | Note Added: 0008817 | |
2007-09-10 09:21 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-10 09:21 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-10 09:21 | Utkarsh Ayachit | Note Added: 0008900 | |
2007-09-13 16:58 | Alan Scott | Status | @80@ => closed |
