0003767 | ParaView | (No Category) | public | 2006-09-13 16:35 | 2009-12-09 16:17 | ||||
Reporter | Kevin Hobbs | ||||||||
Summary | 0003767: Clip hang | ||||||||
Description | Some time recently clip has stopped working in Paraview from CVS HEAD. All I have to do is open paraview, bring up a source like wavelet, and clip it, and the render window becomes mostly unresponsive. I cannot rotate the object, change the clipping plane, and the object drawn does not change when the window is resized. I can click on buttons and delete filters but the only way to render something else is to close paraview. Paraview was compiled with gcc. Paraview was linked against Mesa-6.4.2 without dri compiled from source. This is Linux gargon.hooperlab 2.6.17-1.2174_FC5 #1 SMP Tue Aug 8 15:30:44 EDT 2006 x86_64 x86_64 x86_64 GNU/Linux | ||||||||
Attached Files | bt.txt [^] (7,147 bytes) 1969-12-31 19:00 [Show Content] | ||||||||
(0004914) Kevin Hobbs (reporter) 2006-09-14 11:41 |
The render window also freezes when I threshold the wavelet. I am able to save the output of both the clip and threshold to a '.vtu' file and in both cases the render window freezes as soon as I load the saved data. Could this be an unstructured grid problem? |
(0004915) Kevin Hobbs (reporter) 2006-09-14 13:15 |
I changed to debug mode and did "make clean && make" and I get : terminate called after throwing an instance of 'std::bad_alloc' what(): St9bad_alloc |
(0004916) Kevin Hobbs (reporter) 2006-09-14 13:40 |
I produced a backtrace frome the 1.1 GB core that paraview produced and atached it in bt.txt. |
(0004917) Kevin Hobbs (reporter) 2006-09-14 14:32 |
#8 0x00002aaaaf3c899b in vtkOpenGLTexture::Load (this=0x2a43e80, ren=0xa6b1a0) at /home/kevin/kitware/ParaView/VTK/Rendering/vtkOpenGLTexture.cxx:202 This line is : resultData = new unsigned char [rowLength*ysize]; ddd tells me that rowLength and ysize are monstrous negative numbers when I put a breakpoint there. xsize is also a huge negative number. size[0] = 256, size[1] = 1, and size[2] = 1 do these make sense? |
(0004925) Kevin Hobbs (reporter) 2006-09-15 14:14 |
I did a clean build today starting with "rm -r *" in the build directory. The behavior is the same as yesterday except now ParaView does not immediately exit when I update the clip, and it produces the message below when I click on the render viewport. ErrorMessage # Error or warning: There was a VTK Error in file: /home/kevin/kitware/ParaView/GUI/Widgets/vtkKWApplication.cxx (999) vtkPVApplication (0x7024c0): TclTk error: Uncaught exception: St9bad_alloc Uncaught exception: St9bad_alloc while executing "vtkTemp2 MouseAction 2 1 274 87 0 0" (command bound to event) ErrorMessage end |
(0004932) Kevin Hobbs (reporter) 2006-09-15 16:44 |
I can now relate this bug to one of the tests that fail on gargon.hooperlab, that is : http://paraview.org/Testing/Sites/gargon.hooperlab/Linux-c++/20060915-1537-Experimental/Results/__GUI_Testing_Tcl_CalcInput-batch-ParaView.html [^] I copied the file "/home/kevin/kitware/ParaView/GUI/Testing/Tcl/CalcInput.pvs" and commented out the lines that source things and close the window : diff /home/kevin/kitware/ParaView/GUI/Testing/Tcl/CalcInput.pvs CalcInput.pvs 4,5c4,5 < source [file join [file dirname [info script]] CommandLineOptions.tcl] < ParseCommandLine $pv(vtkTemp43) $argv $argc --- > #source [file join [file dirname [info script]] CommandLineOptions.tcl] > #ParseCommandLine $pv(vtkTemp43) $argv $argc 49,50c49,50 < source [file join [file dirname [info script]] Compare.tcl] < Compare $Application $argv $argc --- > #source [file join [file dirname [info script]] Compare.tcl] > #Compare $Application $argv $argc 52c52 < $Application Exit --- > #$Application Exit When I run "paraview CalcInput.pvs" ParaView is left in the same frozen render viewport state I've described before. I can see only the sphere. If I click on the render viewport I get the message below and ParaView exits. terminate called after throwing an instance of 'std::bad_alloc' what(): St9bad_alloc Aborted |
(0004960) Kevin Hobbs (reporter) 2006-09-18 11:43 |
It looks to me like FindPowerOfTwo is returning crazy numbers. It proceeds through the for loop and sets size to 265. Then after glGetIntegerv, maxDimGL is a huge negative number so of course size is set to this huge negative number. I don't have debug symbols for glGetIntegerv, so I have no idea what it's doing. |
(0004969) Kevin Hobbs (reporter) 2006-09-19 09:37 |
I noticed that the of the ClipCut tests run on gargon batch failed while the ClientServer and RenderServer tests passed. I tried my little test where I bring up the wavelet source and clip it in paraview with offscreen rendering on and it works. Without offscreen rendering the viewport hangs and mesa complains about the invalid context. I just tried some things on our Beowulf cluster as pvserver and my workstation as the pvclient. I tried opening up the wavelet source ( worked ), contouring ( worked ), color by process id ( worked ), but as soon as I clip anything the pvserver dies with a segfault. The pvserver complained as below but it was run with --use-offscreen-rendering. The server was built with mesa as the only GL. Connected to client Process id: 0 >> ERROR: In /home/khobbs/kitware/ParaView/VTK/Rendering/vtkXOpenG LRenderWindow.cxx, line 482 vtkXOpenGLRenderWindow (0x936aba0): bad X server connection. Process id: 0 >> ERROR: In /home/khobbs/kitware/ParaView/VTK/Rendering/vtkXOpenG LRenderWindow.cxx, line 309 vtkXOpenGLRenderWindow (0x936aba0): bad X server connection. mpiexec: Warning: task 0 died with signal 11 (Segmentation fault). |
(0004975) Kevin Hobbs (reporter) 2006-09-19 15:16 |
It looks like the bug 3767 and many of the tests that were failing on my computer were due to my use of the osmesa library. Changing only the VTK_OPENGL_HAS_OSMESA cmake setting got rid of most of the errors and the hang. The bug is : http://paraview.org/Bug/bug.php?op=show&bugid=3767&pos=4 [^] The failing tests are : http://paraview.org/Testing/Sites/gargon.hooperlab/Linux-c++/20060918-1915-Experimental/Test.html [^] |
(0005059) Kevin Hobbs (reporter) 2006-09-28 08:09 |
According to Utkarsh Ayachit the root cause of this bug is a bug in Mesa. He has provided a patch on the mailing list that avoids the bug. It has something to do with the 'HAVS mapper'. Here is his message : http://public.kitware.com/pipermail/paraview/2006-September/003783.html [^] |
2009-12-09 16:17 | Berk Geveci | Status | tabled => closed |
2009-12-09 16:17 | Berk Geveci | Resolution | open => fixed |
