0003840 | ParaView | (No Category) | public | 2006-10-04 13:47 | 2006-11-30 22:15 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0003840: server connect command sometimes doesn't work | ||||||||
Description | So I made a little convenience script (called runserver) ============================================= #!/bin/bash echo "attempting to run server..." # first command > /home/cjstimp/paraview/tryrun /home/cjstimp/paraview/build-mpi/bin/pvserver 2>1 >> /home/cjstimp/paraview/tryrun & # second command #/home/cjstimp/paraview/build-mpi/bin/pvserver & echo "started server..." >> /home/cjstimp/paraview/tryrun It works. If I use the second command instead, it NEVER works. If I use the second command, and add a "sleep 1" at the end of the script, then the ParaView client will crash. If I manually run the script (either first or second command), and manually connect the client to the server, it always works. This is from Linux to Linux (localhost). | ||||||||
(0005719) Clinton Stimpson (developer) 2006-11-14 18:56 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.cxx,v <-- pqCommandServerStartup.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.h,v <-- pqCommandServerStartup.h new revision: 1.6; previous revision: 1.5 |
