0003863 | ParaView | (No Category) | public | 2006-10-06 17:04 | 2006-10-11 17:13 | ||||
Summary | 0003863: Default LOD settings bad | ||||||||
Description | The default LOD settings are bad. In particular geometric LOD is turned off and its threshold is set to 0 when on. The LOD settings should follow that of ParaView 2. The one exception is that the Composite Threshold should be lower. I think our agreed upon value was 3MB. | ||||||||
(0005358) Utkarsh Ayachit (administrator) 2006-10-11 17:13 |
cvs ci -m"BUG: fixed BUG# 3863. Added default render module values based on those in ParaView except that CompositeThreshold is set to 3 MB." Qt ? Qt/Core/pqCameraManipulatorGUIHelper.h Checking for path: /cvsroot/ParaView3/ParaView3/Qt/Core Unrestricted user: utkarsh /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineBuilder.cxx,v <-- pqPipelineBuilder.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderModule.cxx,v <-- pqRenderModule.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderModule.h,v <-- pqRenderModule.h new revision: 1.9; previous revision: 1.8 |
