0003884 | ParaView | (No Category) | public | 2006-10-06 18:32 | 2006-11-30 21:51 | ||||
Assigned To | Corey McBride | ||||||||
Summary | 0003884: Entering contour values | ||||||||
Description | Changing countour values is cumbersome. You have to double click the value. The value then dissapears and you type in a new one. What should happen is that when I double click (or perhaps single click) a value, the value stays but becomes selected so that as I start to type it gets replaced. It would be nice if there was a way to pop up a slider to select the value, too (as ParaView 2 provides). | ||||||||
(0005635) Corey McBride (reporter) 2006-11-01 15:02 |
When you change a value you now select click the value. The value becomes selected so that as you start typing it gets replaced. It is possible to add a slider. However, Berk thinks that it isn't needed. |
