0004027 | ParaView | (No Category) | public | 2006-11-07 11:26 | 2009-12-09 14:51 | ||||
Reporter | David Karelitz | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0004027: SNL: Crash with empty dataset and Ordered Compositing | ||||||||
Description | If a node has no data and enable ordered compositing is checked, pvserver crashes with the following error: Process id: 0 >> ERROR: In /projects/viz/paraview/src/ParaView/2.4.4/ParaView/VTK/Parallel/vtkPKdTree.cxx, line 329 vtkPKdTree (0xac4c1c0): (process 0) VolumeBounds - degenerate volume Process id: 1 >> ERROR: In /projects/viz/paraview/src/ParaView/2.4.4/ParaView/VTK/Parallel/vtkPKdTree.cxx, line 329 vtkPKdTree (0xb8d8840): (process 1) VolumeBounds - degenerate volume To replicate the problem: 1. Start paraview in client/server mode with 2 servers 1. Make sure enable ordered compositing is off 2. Open an Exodus file 3. Apply a threshold that results in an empty dataset (set threshold range to something outside the current variable range) 4. Enable ordered compositing 5. rotate the (empty) dataset | ||||||||
(0005668) Ken Moreland (manager) 2006-11-07 14:13 |
I was able to replicate this problem with ParaView 2.4.4 (BTW you had to set the compositing threshold to 0MB first). However, everything seems to be working fine on the CVS head. Since the release of ParaView 2.4, there have been many fixes to the parallel volume rendering. This must be one of them. |
