0004052 | ParaView | (No Category) | public | 2006-11-20 15:07 | 2006-11-30 20:45 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0004052: vtkExtractHistogram problem | ||||||||
Description | The attached vtu file has two cells/elements. The first cell has a blockId of 1, and the second with a blockId of 2. If I create a histogram with two bins on the block ids, the highest block number is always discarded. This happens on larger models too, where you can have lots of elements/cells that aren't in the histogram. | ||||||||
Attached Files | 2block_0.vtu [^] (1,908 bytes) 1969-12-31 19:00 | ||||||||
(0005755) Clinton Stimpson (developer) 2006-11-22 12:25 |
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.cxx,v <-- vtkExtractHistogram.cxx new revision: 1.12; previous revision: 1.11 No more discarded values. |
