0004062 | ParaView | (No Category) | public | 2006-11-22 17:23 | 2009-05-13 13:47 | ||||
Priority | low | Severity | feature | Reproducibility | always | ||||
Summary | 0004062: Extension independent reader chooser | ||||||||
Description | Right now, ParaView uses the file extension to determine what type of reader to use for a file. Unfortunatly, it is not always clear by the file extension what the format for the file is. It would be much better to give readers the capability to determine for themselves whether they can read a file. For each reader, there could be a mechanism (which may be independent from the actual reader) that could introspect the file (read some header information) and determine if the file is definitely readable, possibly readable, or definitely not readable. If exactly one reader says it can definitely read the file, use that reader. Otherwise, present to the user the subset of readers that can definitely or possibly read the file. | ||||||||
(0011112) Berk Geveci (administrator) 2008-04-07 16:13 |
Take out all readers that can't read a file from the list that is presented to the user. |
(0016249) Ken Moreland (manager) 2009-04-29 13:32 |
Implemented the basic functionality of removing all readers from the list that report they cannot read the file. Of course, the more reader support CanReadFile, the better this functionality works. I'm going to take a look at some of the readers to see if we can easily add CanReadFile before closing this off. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectReaderDialog.cxx,v <-- Components/pqSelectReaderDialog.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqReaderFactory.cxx,v <-- Core/pqReaderFactory.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Qt/Core/pqReaderFactory.h,v <-- Core/pqReaderFactory.h new revision: 1.9; previous revision: 1.8 |
(0016251) Ken Moreland (manager) 2009-04-29 15:06 |
Also needed to change a couple of tests. /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/Plot3DReader.xml,v <-- Testing/XML/Plot3DReader.xml new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/SelectReader.xml,v <-- Testing/XML/SelectReader.xml new revision: 1.14; previous revision: 1.13 |
(0016272) Ken Moreland (manager) 2009-05-01 09:28 |
Added CanReadFile to several readers. This is probably about as good as it's going to get. /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/Plot3DReader.xml,v <-- Applications/Client/Testing/XML/Plot3DReader.xml new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectReaderDialog.ui, v <-- Qt/Components/Resources/UI/pqSelectReaderDialog.ui new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVXMLParser.cxx,v <-- Servers/C ommon/vtkPVXMLParser.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVXMLParser.h,v <-- Servers/Com mon/vtkPVXMLParser.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPPhastaReader.cxx,v <-- Server s/Filters/vtkPPhastaReader.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPPhastaReader.h,v <-- Servers/ Filters/vtkPPhastaReader.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkVRMLSource.cxx,v <-- Servers/F ilters/vtkVRMLSource.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkVRMLSource.h,v <-- Servers/Fil ters/vtkVRMLSource.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkFacetReader.cxx,v <-- VTK/Hybrid/vt kFacetReader.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkFacetReader.h,v <-- VTK/Hybrid/vtkF acetReader.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkBYUReader.cxx,v <-- VTK/IO/vtkBYUReader .cxx new revision: 1.52; previous revision: 1.51 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkBYUReader.h,v <-- VTK/IO/vtkBYUReader.h new revision: 1.47; previous revision: 1.46 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkGenericEnSightReader.cxx,v <-- VTK/IO/v tkGenericEnSightReader.cxx new revision: 1.87; previous revision: 1.86 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkGenericEnSightReader.h,v <-- VTK/IO/vtk GenericEnSightReader.h new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkNetCDFCOARDSReader.cxx,v <-- VTK/IO/vtk NetCDFCOARDSReader.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkNetCDFCOARDSReader.h,v <-- VTK/IO/vtkNe tCDFCOARDSReader.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkPLYReader.cxx,v <-- VTK/IO/vtkPLYReader .cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkPLYReader.h,v <-- VTK/IO/vtkPLYReader.h new revision: 1.10; previous revision: 1.9 |
(0016321) Alan Scott (manager) 2009-05-06 16:54 |
This seems to work for the few files I have tested. I am closing this, with the understanding that if anyone starts reporting errors we will re-open it. Tested local client. |
2008-04-07 16:13 | Berk Geveci | Note Added: 0011112 | |
2008-04-07 16:13 | Berk Geveci | Category | => 3.6 |
2009-02-16 14:41 | Ken Moreland | Assigned To | Berk Geveci => Burlen |
2009-04-29 13:29 | Ken Moreland | Assigned To | Burlen => Ken Moreland |
2009-04-29 13:32 | Ken Moreland | Note Added: 0016249 | |
2009-04-29 15:06 | Ken Moreland | Note Added: 0016251 | |
2009-05-01 09:28 | Ken Moreland | Note Added: 0016272 | |
2009-05-01 09:28 | Ken Moreland | Status | tabled => @80@ |
2009-05-01 09:28 | Ken Moreland | Resolution | open => fixed |
2009-05-06 16:54 | Alan Scott | Note Added: 0016321 | |
2009-05-06 16:54 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
