0004065 | ParaView | (No Category) | public | 2006-11-22 17:54 | 2007-08-21 12:06 | ||||
Reporter | John Greenfield | ||||||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0004065: CTH Extract Parts Error | ||||||||
Description | If you load a cth file and try cth part filter it will seg fault. On my windows machine it also hangs the second video port (i.e. primary video still works but second port on card is frozen until reboot). Need to fix before sandia release. | ||||||||
(0006748) Berk Geveci (administrator) 2007-03-12 16:16 |
Does this happen with any data file? |
(0006963) John Greenfield (reporter) 2007-03-27 15:58 |
It hapens with every file I have been able to find. It may just be that the GUI is wrong (Ken has a newer bug on this), but I think it should at least fail without seg faulting paraview. Incidentally, the seg fault will happen if you open an exodus file and try ExtractCTHParts on it -- looks like an illegal memory reference. |
(0006972) Berk Geveci (administrator) 2007-03-28 13:31 |
I am pretty sure this is a problem with the GUI (although mine produces an error instead of crashing). We will need to write a custom panel for this filter. |
(0006986) Clinton Stimpson (developer) 2007-03-28 18:40 |
If we instead use a StringVectorProperty with an ArraySelectionDomain, the GUI will automatically generate list view with check boxes. Will that work with vtkExtractCTHParts? |
(0006988) Berk Geveci (administrator) 2007-03-29 08:07 |
No. The ExtractCTH filter works only with some arrays. We don't have a domain for this yet. I am not sure if it easier to write a domain or a custom panel. I will leave the judgment call to Utkarsh. |
(0007022) Utkarsh Ayachit (administrator) 2007-03-30 13:38 |
A auto generated panel has been added to the CTH extract part filter. |
(0008520) Utkarsh Ayachit (administrator) 2007-08-20 14:03 |
This old bug seems to have got un-resolved during bug-tracker migration. |
2007-08-07 16:10 | Zack Galbreath | Project | @9@ => ParaView |
2007-08-07 16:11 | Zack Galbreath | Status | backlog => tabled |
2007-08-07 16:11 | Zack Galbreath | Assigned To | David Cole => Utkarsh Ayachit |
2007-08-08 14:46 | John Greenfield | Severity | minor => major |
2007-08-08 14:46 | John Greenfield | Summary | Goodsite => CTH Extract Parts Error |
2007-08-13 14:07 | Berk Geveci | Note Deleted: 0008173 | |
2007-08-20 14:03 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-20 14:03 | Utkarsh Ayachit | Resolution | reopened => no change required |
2007-08-20 14:03 | Utkarsh Ayachit | Note Added: 0008520 | |
2007-08-21 12:06 | Ken Moreland | Status | @80@ => closed |
