0004094 | ParaView | (No Category) | public | 2006-11-29 15:59 | 2009-12-09 14:50 | ||||
Reporter | Jeff | ||||||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0004094: missing correct libGL.1.dylib file | ||||||||
Description | After installing paraview-2.4.4-darwin, attemped to run paraview and obtained the error message: dyld: Library not loaded: /usr/X11R6/lib/libGL.1.dylib Referenced from: /usr/local/lib/paraview-2.4/paraview-real Reason: image not found Trace/BPT trap I located in the "Mac Framework OpenGL" area a copy of libGL.dylib, copied its name to libGL.1.dylib, and placed it in /usr/X11R6/lib, and re-ran paraview. The new message was: dyld: Library not loaded: /usr/X11R6/lib/libGL.1.dylib Referenced from: /usr/local/lib/paraview-2.4/paraview-real Reason: Incompatible library version: paraview-real requires version 1.2.0 or later, but libGL.1.dylib provides version 1.0.0 Trace/BPT trap Where can I find the correct versions of the libGL's to use with paraview? | ||||||||
(0007782) Berk Geveci (administrator) 2007-06-02 09:43 |
paraview 2 required X installation. paraview 3 should work without problem. |
2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView |
