0004108 | ParaView | (No Category) | public | 2006-12-01 09:25 | 2007-04-04 16:14 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004108: Single line command for client/server launching | ||||||||
Description | ParaView 2 has the ability to launch the client with a command line flag so it waits for a server connection. We need either that functionality or the ability to specify a server name from the connection list to automatically connect to when ParaView starts up. This is so our existing paraview2cluster scripts used by DART will continue to work. | ||||||||
(0005873) Ken Moreland (manager) 2006-12-04 19:15 |
I prefer the second solution. It is easy to make a server that simply waits for a connection. It also makes it easier to implement the paraview2cluster, since ParaView can do all the work launching and connecting to the server. |
(0006918) Utkarsh Ayachit (administrator) 2007-03-23 09:12 |
ENH: Fixed BUG 0004108. --server(-s) can be used to specify a server resource name on the command line. ENH: Initial ground work for support for versioning (BUG 0004143). Added version number to state file. ProxyManager warns if the state file does not have a version number. ENH: Cleaned up vtkSMProxyManager::SaveState() api. BUG: Removed obsolete pqJoystickFly class. We use the vtkPVJoystickFly instead with a camera manipulator GUI helper. /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.96; previous revision: 1.95 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLookmarkDefinitionWizard.cxx,v <-- pqLookmarkDefinitionWizard.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.141; previous revision: 1.140 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.57; previous revision: 1.56 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- pqViewManager.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.66; previous revision: 1.65 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.65; previous revision: 1.64 /cvsroot/ParaView3/ParaView3/Qt/Core/pqJoystickFly.cxx,v <-- pqJoystickFly.cxx new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqJoystickFly.h,v <-- pqJoystickFly.h new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOptions.cxx,v <-- pqOptions.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOptions.h,v <-- pqOptions.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProcessModuleGUIHelper.cxx,v <-- pqProcessModuleGUIHelper.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVOptions.cxx,v <-- vtkPVOptions.cxx new revision: 1.39; previous revision: 1.38 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVMain.cxx,v <-- vtkPVMain.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.cxx,v <-- vtkSMProxyManager.cxx new revision: 1.63; previous revision: 1.62 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.h,v <-- vtkSMProxyManager.h new revision: 1.45; previous revision: 1.44 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMServerProxyManagerReviver.cxx,v <-- vtkSMServerProxyManagerReviver.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.cxx,v <-- vtkSMStateLoader.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.h,v <-- vtkSMStateLoader.h new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.145; previous revision: 1.144 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/writers.xml,v <-- writers.xml new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/Animation.pvsm,v <-- Animation.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/Arrow.pvsm,v <-- Arrow.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/Axes.pvsm,v <-- Axes.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/BlowTest.pvsm,v <-- BlowTest.pvsmnew revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/BoundsDisplay.pvsm,v <-- BoundsDisplay.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/CalcInput.pvsm,v <-- CalcInput.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ClipCut.pvsm,v <-- ClipCut.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/CompoundProxyUndoRedo.pvsm,v <-- CompoundProxyUndoRedo.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ExtractGrid.pvsm,v <-- ExtractGrid.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ProxyPropertyLinks.pvsm,v <-- ProxyPropertyLinks.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/SPCTH2.pvsm,v <-- SPCTH2.pvsm new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/TestPHT.pvsm,v <-- TestPHT.pvsm new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/UndoRedo.pvsm,v <-- UndoRedo.pvsmnew revision: 1.6; previous revision: 1.5 |
(0007078) Ken Moreland (manager) 2007-04-02 18:26 |
This mechanism does not seem to support reverse-connections, which we need for our distributions within Sandia. When you try to apply a reverse server connection, you get the following: "Server reverse connections not supported yet Could not connect to requested server " Manual ". Creating default builtin connection. " |
(0007099) Utkarsh Ayachit (administrator) 2007-04-03 11:56 |
ENH: pqSimpleServerStartup now supports a blocking mode to create a server connection. BUG: Fixes BUG# 4108. Was incorrectly using the pqApplicationCore::createServer() which does not know about reverse connections etc. Now using the pqSimpleServerStartup that can ask for user options/reverse connections etc etc. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.162; previous revision: 1.161 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSimpleServerStartup.cxx,v <-- pqSimpleServerStartup.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSimpleServerStartup.h,v <-- pqSimpleServerStartup.h new revision: 1.7; previous revision: 1.6 |
