0004130ParaView(No Category)public2006-12-04 18:402009-05-13 13:59
ReporterKen Moreland
Assigned ToClinton Stimpson
PrioritynormalSeverityfeatureReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.4Fixed in Version3.4
Summary0004130: Context sensitive doc of each filter
DescriptionThere needs to be documentation of each filter, that is easy to jump to when using that filter.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
related to 0006728closedClinton Stimpson Tooltips for object inspector
  Notes
(0007772)
Berk Geveci (administrator)
2007-06-02 08:57
The documentation is there now we need to make the help come up with the right page.
(0011379)
Clinton Stimpson (developer)
2008-04-15 18:44
Fixed. There's a new help button in the object inspector.
(0011423)
Alan Scott (manager)
2008-04-17 19:53
This only works if the user runs ParaView from the ParaView3 directory - not the ParaView3/bin directory. If you step into the bin directory and run paraview.exe, or run from somewhere else (for instance ../ParaView3/bin/paraview.exe), this fails.
An example failure output is as follows:
The page could not be found
'file:///c:/alan/paraviewnightlytrunk/scripts/documentation/clip.html' [^]
Note that my file structure is as follows:
scripts (where I have a script that starts ParaView client/server)
bld/ParaView3, where the bin directory actually is.
src/ParaView3.
(0011433)
2008-04-18 13:00
Good find. Fixed.
/cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx
new revision: 1.142; previous revision: 1.141
(0011471)
2008-04-21 20:45
Sorry, still fails. At least it has changed where it is looking...
'file:///c:/windows/system32/documentation/clip.html' [^]
(0011539)
2008-04-24 17:31
I'm not able to reproduce the error. I don't see how it can even end up with c:/windows/system32/documentation, unless you have a stray pqClient.adp in the system32 folder, and your paraview.exe was some place relative to system32.
(0011540)
2008-04-24 17:54
It works now. I have no idea why it was giving troubles.
Closed, tested client/server.
 Issue History
2007-08-13 15:22 Berk Geveci Priority normal => high
2007-08-23 17:10 Berk Geveci Category => 3.2
2007-10-18 13:27 Berk Geveci Priority high => normal
2008-04-07 16:17 Berk Geveci Assigned To Mark Richardson => Clinton Stimpson
2008-04-07 16:17 Berk Geveci Category => 3.4
2008-04-14 12:51 Ken Moreland Relationship added related to 0006728
2008-04-15 18:44 Clinton Stimpson Status tabled => @80@
2008-04-15 18:44 Clinton Stimpson Resolution open => fixed
2008-04-15 18:44 Clinton Stimpson Note Added: 0011379
2008-04-17 19:53 Alan Scott Status @80@ => @20@
2008-04-17 19:53 Alan Scott Resolution fixed => reopened
2008-04-17 19:53 Alan Scott Note Added: 0011423
2008-04-18 13:00 Clinton Stimpson Status @20@ => @80@
2008-04-18 13:00 Clinton Stimpson Resolution reopened => fixed
2008-04-18 13:00 Clinton Stimpson Note Added: 0011433
2008-04-21 20:45 Alan Scott Status @80@ => @20@
2008-04-21 20:45 Alan Scott Resolution fixed => reopened
2008-04-21 20:45 Alan Scott Note Added: 0011471
2008-04-24 17:31 Clinton Stimpson Note Added: 0011539
2008-04-24 17:54 Alan Scott Status @20@ => closed
2008-04-24 17:54 Alan Scott Note Added: 0011540
2008-04-24 17:54 Alan Scott Resolution reopened => fixed
2009-05-13 13:58 Utkarsh Ayachit Target Version => 3.4
2009-05-13 13:59 Utkarsh Ayachit Fixed in Version => 3.4
