0004132 | ParaView | (No Category) | public | 2006-12-04 18:56 | 2007-03-05 23:25 | ||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0004132: Select a frustum | ||||||||
Description | Right now when you select, you always select the cells visible under the rubber band. It should also be possible to select all the cells that fall within the volume contained within the rubber band. | ||||||||
(0006566) user521 2007-02-26 17:05 |
I added this in today. To do a frustum selection, go to the edit menu and choose "select through". |
(0006641) Ken Moreland (manager) 2007-03-05 23:25 |
This appears to work, but as I tried it I see a serious bug has been introduced with the selection. I don't know if the completion of this feature request has anything to do with the introduction of the new bug (registered as 4535) |
