0004134 | ParaView | (No Category) | public | 2006-12-04 19:02 | 2009-05-13 13:46 | ||||
Summary | 0004134: Selectable property to props | ||||||||
Description | It should be possible to make an object visible without allowing anything to be selected on it. One idea was to have a column in the pipeline browser next to the visibility column that would have similar functionality except that it would turn on/off pickablility. However, this will probably use up too much screen real estate for a feature that will be turned on/off sporatically. A better solution may be to add an option to the display tab. | ||||||||
(0015211) Utkarsh Ayachit (administrator) 2009-02-19 10:03 |
Added "Selectable" checkbox to the display tab which controls is the prop is selectable. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- Qt/Components/pqDisplayProxyEditor.cxx new revision: 1.70; previous revision: 1.69 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- Qt/Components/Resources/UI/pqDisplayProxyEditor.ui new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMRenderViewProxy.cxx new revision: 1.85; previous revision: 1.84 |
(0015411) Alan Scott (manager) 2009-02-25 20:49 |
Tested client/ remote server. |
2008-04-07 16:21 | Berk Geveci | Assigned To | Dave DeMarle => Berk Geveci |
2008-04-07 16:21 | Berk Geveci | Category | => 3.6 |
2009-02-16 14:43 | Ken Moreland | Assigned To | Berk Geveci => Utkarsh Ayachit |
2009-02-19 10:03 | Utkarsh Ayachit | Note Added: 0015211 | |
2009-02-19 10:03 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-02-19 10:03 | Utkarsh Ayachit | Resolution | open => fixed |
2009-02-25 20:49 | Alan Scott | Note Added: 0015411 | |
2009-02-25 20:49 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
