0004143 | ParaView | (No Category) | public | 2006-12-05 15:11 | 2008-04-07 16:23 | ||||
Priority | low | Severity | feature | Reproducibility | always | ||||
Summary | 0004143: Server manager state backward compatibility | ||||||||
Description | We should try to ensure that the server manager state files can maintain backward compatibility. One big problem we have had with ParaView state files is that they become invalid any time ParaView is updated. At a minimum, the state file needs to save the version of ParaView that created the file. That way future versions can make adjustments accordingly. It would also be good if ParaView did something intelligent when errors are encountered from reading the state file, which can happen if the server manager definition files change unexpectedly. However, we can probably defer that to the next version of ParaView when there will actually be an issue with backward compatibility. | ||||||||
(0006592) Clinton Stimpson (developer) 2007-02-28 16:08 |
See bug 0004504 |
(0006917) Utkarsh Ayachit (administrator) 2007-03-23 09:12 |
ENH: Fixed BUG 0004108. --server(-s) can be used to specify a server resource name on the command line. ENH: Initial ground work for support for versioning (BUG 0004143). Added version number to state file. ProxyManager warns if the state file does not have a version number. ENH: Cleaned up vtkSMProxyManager::SaveState() api. BUG: Removed obsolete pqJoystickFly class. We use the vtkPVJoystickFly instead with a camera manipulator GUI helper. /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.96; previous revision: 1.95 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLookmarkDefinitionWizard.cxx,v <-- pqLookmarkDefinitionWizard.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.141; previous revision: 1.140 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.57; previous revision: 1.56 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- pqViewManager.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.66; previous revision: 1.65 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.65; previous revision: 1.64 /cvsroot/ParaView3/ParaView3/Qt/Core/pqJoystickFly.cxx,v <-- pqJoystickFly.cxx new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqJoystickFly.h,v <-- pqJoystickFly.h new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOptions.cxx,v <-- pqOptions.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOptions.h,v <-- pqOptions.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProcessModuleGUIHelper.cxx,v <-- pqProcessModuleGUIHelper.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVOptions.cxx,v <-- vtkPVOptions.cxx new revision: 1.39; previous revision: 1.38 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVMain.cxx,v <-- vtkPVMain.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.cxx,v <-- vtkSMProxyManager.cxx new revision: 1.63; previous revision: 1.62 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.h,v <-- vtkSMProxyManager.h new revision: 1.45; previous revision: 1.44 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMServerProxyManagerReviver.cxx,v <-- vtkSMServerProxyManagerReviver.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.cxx,v <-- vtkSMStateLoader.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.h,v <-- vtkSMStateLoader.h new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.145; previous revision: 1.144 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/writers.xml,v <-- writers.xml new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/Animation.pvsm,v <-- Animation.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/Arrow.pvsm,v <-- Arrow.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/Axes.pvsm,v <-- Axes.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/BlowTest.pvsm,v <-- BlowTest.pvsmnew revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/BoundsDisplay.pvsm,v <-- BoundsDisplay.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/CalcInput.pvsm,v <-- CalcInput.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ClipCut.pvsm,v <-- ClipCut.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/CompoundProxyUndoRedo.pvsm,v <-- CompoundProxyUndoRedo.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ExtractGrid.pvsm,v <-- ExtractGrid.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ProxyPropertyLinks.pvsm,v <-- ProxyPropertyLinks.pvsm new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/SPCTH2.pvsm,v <-- SPCTH2.pvsm new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/TestPHT.pvsm,v <-- TestPHT.pvsm new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/UndoRedo.pvsm,v <-- UndoRedo.pvsmnew revision: 1.6; previous revision: 1.5 |
2008-04-07 16:23 | Berk Geveci | Status | tabled => closed |
2008-04-07 16:23 | Berk Geveci | Resolution | open => fixed |
