0004172 | ParaView | (No Category) | public | 2006-12-07 17:59 | 2007-01-03 17:54 | ||||
Priority | urgent | Severity | minor | Reproducibility | always | ||||
Summary | 0004172: Bigger Exodus checkbox targets | ||||||||
Description | When selecting and unselecting variables in the Exodus reader Properties panel, you have to click right in the checkbox. You should be able to check or uncheck a line by simply clicking anywhere on the line containing the checkbox. The same is true for the blocks and sets checkboxes. | ||||||||
(0005927) Utkarsh Ayachit (administrator) 2006-12-08 15:33 |
Added new check helper classes for ListWidget and TreeWidget which help change the check status when user clicks on the entire row in the widget. Changed exodus widgets, plot widgets and array selection widgets to use this helper. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAutoGeneratedObjectPanel.cxx,v <-- pqAutoGeneratedObjectPanel.cxx new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.cxx,v <-- pqExodusPanel.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Components/pqXYPlotDisplayProxyEditor.cxx,v <-- pqXYPlotDisplayProxyEditor.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Widgets/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqListWidgetCheckHelper.cxx,v <-- pqListWidgetCheckHelper.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqListWidgetCheckHelper.h,v <-- pqListWidgetCheckHelper.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqTreeWidgetCheckHelper.cxx,v <-- pqTreeWidgetCheckHelper.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqTreeWidgetCheckHelper.h,v <-- pqTreeWidgetCheckHelper.h initial revision: 1.1 |
(0005973) Clinton Stimpson (developer) 2006-12-13 18:24 |
This interferes with other standard item view interactions. What about selecting multiple items and right clicking to get a context menu? The check states have changed while making the multiple selection. And what about when items are editable? We should be able to edit an item without changing the check state. We should have all item views in the GUI be consistent in their behaviors. Right now, they aren't. Re-opening for reconsideration. |
(0005978) Utkarsh Ayachit (administrator) 2006-12-14 08:37 |
As Clint has pointed out, this conflicts with Bug 0004173 |
(0006034) Utkarsh Ayachit (administrator) 2006-12-21 13:17 |
Resolving this Bug since the issue raised has been captured by BUG 0004173. |
