0004184 | ParaView | (No Category) | public | 2006-12-08 11:12 | 2007-01-03 17:54 | ||||
Reporter | Clinton Stimpson | ||||||||
Priority | urgent | Severity | feature | Reproducibility | always | ||||
Summary | 0004184: add ability to revert to default light values on render module | ||||||||
Description | with light settings saved with QSettings, it would be nice to provide a reset ability to get the default light properties back. Ideally, with the new defaults mechanism in the server manager. | ||||||||
(0006006) Clinton Stimpson (developer) 2006-12-19 11:44 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.15; previous revision: 1.14 Implemented client side reset of lights. We just need to implement the server manager side of it. The default value mechanism needs to be extended to include the render module. |
(0006007) Clinton Stimpson (developer) 2006-12-19 11:44 |
Do you want this Utkarsh? |
(0006027) Utkarsh Ayachit (administrator) 2006-12-20 12:00 |
vtkSMProperty::ResetToDefault() resets to default value is configuration XML, if applicable. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDoubleVectorProperty.cxx,v <-- vtkSMDoubleVectorProperty.cxx new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDoubleVectorProperty.h,v <-- vtkSMDoubleVectorProperty.h new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIdTypeVectorProperty.cxx,v <-- vtkSMIdTypeVectorProperty.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIdTypeVectorProperty.h,v <-- vtkSMIdTypeVectorProperty.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIntVectorProperty.cxx,v <-- vtkSMIntVectorProperty.cxx new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIntVectorProperty.h,v <-- vtkSMIntVectorProperty.h new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProperty.cxx,v <-- vtkSMProperty.cxx new revision: 1.51; previous revision: 1.50 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProperty.h,v <-- vtkSMProperty.h new revision: 1.41; previous revision: 1.40 |
