0004191 | ParaView | (No Category) | public | 2006-12-11 16:37 | 2011-01-13 17:00 | ||||
Reporter | Clinton Stimpson | ||||||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0004191: LOD crash with exodus nodesets | ||||||||
Description | open an exodus file, and turn a nodeset on. turn LOD threshold to zero MB. Then rotate the model. It crashes in vtkQuadricClustering. Crashes in PV2 also. | ||||||||
Relationships | ||||||
(0008940) Amy Squillacote (reporter) 2007-09-12 11:44 |
This problem has now been fixed. The problem was the result of a typo: when you're copying cell data, it should be from the input to the output, not the output to the output. /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkQuadricClustering.cxx,v <-- vtkQu adricClustering.cxx new revision: 1.78; previous revision: 1.77 |
2007-08-13 16:16 | Berk Geveci | Assigned To | Berk Geveci => Amy Squillacote |
2007-08-13 16:16 | Berk Geveci | Priority | normal => high |
2007-09-11 16:39 | Berk Geveci | Relationship added | has duplicate 0005196 |
2007-09-12 11:44 | Amy Squillacote | Status | tabled => @80@ |
2007-09-12 11:44 | Amy Squillacote | Resolution | open => fixed |
2007-09-12 11:44 | Amy Squillacote | Note Added: 0008940 | |
2007-09-17 18:19 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
