0004196 | ParaView | (No Category) | public | 2006-12-12 15:21 | 2007-02-06 18:17 | ||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0004196: Mesa is broken | ||||||||
Description | Mesa is broken using ParaView 3. Run a normal exodus file, such as can.exo, client/server using Mesa. On hitting Accept, the server will crash with the following: Process id: 0 >> ERROR: In ...bla.../VTK/Rendering/vtkXOpenGLRenderWindow.cxx line 497 vtkXOpenGLRenderWindow: bad X server connection. DISPLAY=.0 This error is caused because the code at/around line 493 does not have an #ifdef VTK_OPENGL_HAS_OSMESA wrapper, and the appropriate code for Mesa. Search in the file for XOpenDisplay, and what I believe is the proper handling of this call is found lower in this file. I am assigning this a high priority because it breaks all of the client server systems at Sandia (except feynman). It needs to be fixed by the January 07 release, if possible. | ||||||||
(0005989) Berk Geveci (administrator) 2006-12-18 11:45 |
SNL prefix is not needed for paraview 3 bugs. |
(0006284) Berk Geveci (administrator) 2007-01-30 11:04 |
The --use-offscreen-rendering option should now work. |
