0004223 | ParaView | (No Category) | public | 2006-12-18 09:19 | 2009-12-09 14:49 | ||||
Reporter | Jean Favre | ||||||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0004223: multiple execution of Image Reader when running PV in parallel | ||||||||
Description | I am having trouble developping a custom reader (public inheritance of vtkImageAlgorithm). When running PV on a single node, my reader executes once only - as expected - and creates a vtkImageData. I can then use any number of Filters downstream When running PV on multiple nodes, my reader executes every time I start a new filter. Can't figure out what triggers it. Forget about my own source code. I went back to the basics and put a DebugOn() statement in vtkImageReader. It exhibits exactly the same behavior: on a single node, execute once and only once as expected. on multiple nodes, executes multiple times. Here is an example running on 2 nodes, First read of a 90^3 raw binary file (the extents are split in the Z direction): Reading extent: 0, 89, 0, 89, 0, 45 Reading extent: 0, 89, 0, 89, 43, 89 then I extracted a I=29 ortho-slice and the reader executed again Reading extent: 29, 29, 0, 89, 0, 89 Reading extent: 29, 29, 0, 89, 0, 89 then I extracted an J=45 orthoslice and the reader executed again Reading extent: 0, 89, 45, 45, 0, 89 Reading extent: 0, 89, 45, 45, 0, 89 then I executed an isosurface and the reader executed again Reading extent: 0, 89, 0, 89, 0, 45 Reading extent: 0, 89, 0, 89, 43, 89 We have only found this multiple execution with ImageData. Other readers (for example for StructuredGrid) do not execute multiple times. | ||||||||
(0007901) Berk Geveci (administrator) 2007-06-17 17:34 |
Fixed bug in vtkExtractVOI. |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
