0004230 | ParaView | (No Category) | public | 2006-12-19 10:01 | 2007-04-02 16:20 | ||||
Summary | 0004230: Orphaned Scalar Bar | ||||||||
Description | If you turn on the scalar bar for an object and then delete that object, its scalar bar is "orphaned." That is, the scalar bar sticks around even after the object is delete. You can click and drag the bar, but there is no way to delete it. | ||||||||
(0006851) Utkarsh Ayachit (administrator) 2007-03-19 23:05 |
When a display is deleted, we hide all scalars bars for the lookup table used by the display is if no other display uses that lookup table. /cvsroot/ParaView3/ParaView3/Qt/Core/pqObjectBuilder.cxx,v <-- pqObjectBuilder.cxx new revision: 1.2; previous revision: 1.1 |
(0006928) Ken Moreland (manager) 2007-03-23 15:02 |
I thought this was fixed, but now I was just able to reproduce it. 1. Create a Sphere source. 2. Add the Elevation filter 3. Show the scalar bar for the Elevation scalars. 4. Delete the Elevation filter. The scalar bar stays around with no way to delete it. (Well, that's not entirely correct. You could create a new elevation filter, and the scalar bar will become attached to the new scalars.) |
(0006931) Utkarsh Ayachit (administrator) 2007-03-23 22:56 |
Strengthed the check of whether a LUT is being used by any source by making sure that the source does indeed have scalar coloring enabled. /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.cxx,v <-- pqScalarsToColors.cxx new revision: 1.11; previous revision: 1.10 |
