0004240 | ParaView | (No Category) | public | 2006-12-21 15:08 | 2007-04-02 17:52 | ||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0004240: Surface selection in par/cli server without compositing broken. | ||||||||
Description | Selection seems not to work with parallel server/ds-rs. To reproduce, enable the SelectionUndo-ClientServer SelectionUndo-RenderServer tests. | ||||||||
(0006035) Utkarsh Ayachit (administrator) 2006-12-21 15:09 |
To enable these tests revert the following changes: /cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.75; previous revision: 1.74 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/SelectionUndo.xml,v <-- SelectionUndo.xml new revision: 1.12; previous revision: 1.11 |
(0006759) user521 2007-03-13 13:58 |
SelectionUndo-ClientServer SelectionUndo-RenderServer tests fail. Because - surface selection in client/server when not compositing is broken. |
(0006763) Berk Geveci (administrator) 2007-03-13 15:11 |
For now, we will force compositing when selecting and produce an error if server cannot render. |
(0007037) user521 2007-04-01 13:23 |
I committed the suggested work around in: Servers/ServerManager/vtkSMRenderModuleProxy.cxx 1.80->1.81 Lets change the priority to 3 so that I remember to do implement a proper solution for 3.1 |
