0004271 | ParaView | (No Category) | public | 2007-01-03 10:00 | 2007-01-09 11:59 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004271: Cannot Control-C ParaView3 | ||||||||
Description | When I run ParaView3 I cannot Control-C it from the terminal | ||||||||
(0006068) Clinton Stimpson (developer) 2007-01-03 15:46 |
Py_Initialize() is doing this. In the past, ctrl-c used to work at startup, but not if the embedded python interpreter was used. |
(0006090) Clinton Stimpson (developer) 2007-01-05 12:17 |
Install default SIGINT handler after Py_Initialize() /cvsroot/ParaView3/ParaView3/Qt/Testing/pqPythonEventSource.cxx,v <-- pqPythonEventSource.cxx new revision: 1.15; previous revision: 1.14 new revision: 1.16; previous revision: 1.15 Should also do it in vtkPVPythonInterpretor.cxx |
(0006092) Clinton Stimpson (developer) 2007-01-05 14:32 |
/cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/Executable/vtkPVPythonInterpretor.cxx,v <-- vtkPVPythonInterpretor.cxx new revision: 1.7; previous revision: 1.6 |
