0004322 | ParaView | (No Category) | public | 2007-01-16 10:43 | 2007-09-25 20:49 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004322: Programmable Filter stdout/stderr | ||||||||
Description | On Windows there doesn't appear to be a way to see the stdout and stderr of the Programmable Filter. On linux the output goes to the console. | ||||||||
(0006726) Berk Geveci (administrator) 2007-03-12 14:12 |
There is really no good solution to this. What if the python filter is running on the server? Are we supposed to somehow get the output from all nodes and bring it back to the client? The user should open a file (or multiple files) and write there or produce an array with the results. |
(0006728) Berk Geveci (administrator) 2007-03-12 14:32 |
The problem really has to do with not seeing the python errors. On linux, you can see stdout/stderr in the console of where the server is run (or in the batch queue output files if running on a cluster). When the server is being run on windows, you can't see the python errors, so there's no way to know if your script is working or not. |
(0006729) Berk Geveci (administrator) 2007-03-12 14:32 |
We should catch python errors and report them with vtkErrorMacro. |
(0009111) Utkarsh Ayachit (administrator) 2007-09-19 09:08 |
Added support to vtkPVPythonInterpretor to capture stdout and stderr messages. Also added new vtkPVPythonInteractiveInterpretor which mimicks the standard python shell's read-eval-print loop. Adding a new bug (BUG 0005748) to capture the delivering of server side messages to client. /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/Executable/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/Executable/vtkPVPythonInteractiveInterpretor.cxx,v <-- vtkPVPythonInteractiveInterpretor.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/Executable/vtkPVPythonInteractiveInterpretor.h,v <-- vtkPVPythonInteractiveInterpretor.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/Executable/vtkPVPythonInterpretor.cxx,v <-- vtkPVPythonInterpretor.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Utilities/VTKPythonWrapping/Executable/vtkPVPythonInterpretor.h,v <-- vtkPVPythonInterpretor.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Python/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Python/pqPythonShell.cxx,v <-- pqPythonShell.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Python/pqPythonShell.h,v <-- pqPythonShell.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Python/pqPythonStream.cxx,v <-- pqPythonStream.cxx new revision: delete; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Python/pqPythonStream.h,v <-- pqPythonStream.h new revision: delete; previous revision: 1.2 |
2007-08-13 16:18 | Berk Geveci | Assigned To | Dave DeMarle => Berk Geveci |
2007-08-13 16:18 | Berk Geveci | Priority | normal => high |
2007-09-17 11:52 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-09-19 09:08 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-19 09:08 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-19 09:08 | Utkarsh Ayachit | Note Added: 0009111 | |
2007-09-25 20:49 | Alan Scott | Status | @80@ => closed |
